Printed circuit
BeitragVerfasst: Donnerstag 12. Juni 2025, 11:02
von Pepitt03
Hello , Hallo ,
I have a problem with it .
Terminal W is cut on the wire near the connection plug.
How to repare ? Or new circuit ?
Some pictures .
Regards .
Bruno.
Re: Printed circuit
BeitragVerfasst: Sonntag 22. Juni 2025, 15:47
von Frank aus MTK
Hi,
You can try to bypass the cut with a wire while carefully soldering with low temp and special low melting point solder as the circuit himself does melt very quick.
If you have someone available with experience in soldering this should be possible.
Good luck
Re: Printed circuit
BeitragVerfasst: Montag 23. Juni 2025, 16:53
von Pepitt03
Ok .
Thanks for your answer .
Bruno.
