Printed circuit
Printed circuit
Beitragvon Pepitt03 » Donnerstag 12. Juni 2025, 11:02
Hello , Hallo ,
I have a problem with it .
Terminal W is cut on the wire near the connection plug.
How to repare ? Or new circuit ?
Some pictures .
Regards .
Bruno.
Pepitt03
Fahrzeug: LT40 4X4 DV 1987
Re: Printed circuit
Beitragvon Frank aus MTK » Sonntag 22. Juni 2025, 15:47
Hi,
You can try to bypass the cut with a wire while carefully soldering with low temp and special low melting point solder as the circuit himself does melt very quick.
If you have someone available with experience in soldering this should be possible.
Good luck
Frank aus MTK
Frank aus MTK
Re: Printed circuit
Beitragvon Pepitt03 » Montag 23. Juni 2025, 16:53
Ok .
Thanks for your answer .
Bruno.
Pepitt03
