Bundas hat geschrieben: what parts do I need for this conversion
Bundas hat geschrieben:It's coming from a Jeep Cherokee XJ pre 1996 with a 4.0 Petrol engine and the badge is 242J.
Bundas hat geschrieben:know a dealer with a webshop
Bundas hat geschrieben:shift leaver laser cutted
Bundas hat geschrieben:Unfortunately I can't see your picture now :)
Bundas hat geschrieben: do you think that the 241 (or 208) mechanical speedo sensor is a straight swap
Bundas hat geschrieben:So the transferbox is now done and running as it should be.
Bundas hat geschrieben:I read a couple of Jeep sites and it seems that for our differential ration and my wheel size (10.5r20) I need to have 41 teeth.
Bundas hat geschrieben:my wheel size (10.5r20)
Bundas hat geschrieben:I haven't put any RTV or sealant on the washer of the RE flange so I think the splines carry a little bit of oil out and it's dripping between the alloy spacer and the RE flange
Bundas hat geschrieben:the rear one is stuck - of course in the locked position
Mitglieder in diesem Forum: Bing [Bot] und 9 Gäste
